I have several mp3 I need to edit and cut pieces out of and paste in to others. Maybe I need to make one mp3 from three mp3’s for example. It is narration not songs.
I understand every time I export the mp3 are being re encoded. is that right. i do not see any deterioration really. It is not hi fi music it just needs to be heard clearly. Still i want quality as much as possible. What i do is play mp3 number one with vlc and record with audacity.Then record number two and paste it in afetr removing the piece i do not want from number one. I do not export until all the pieces are joined correctly. Is it only on exportthe re encode happens. is this the best way to do it?
You can also drag-and-drop the mp3’s into Audacity. As with using import, they will be on separate tracks.
Then you can use Audacity’s time-shift tool to arrange the tracks …
Note no matter what you do with the exported MP3, the quality is still going to go down. Even if you select 256 quality as export, the 128 quality isn’t going to be 128. It will be some quality less, like 96. The final will be 128 quality if you export as WAV (Microsoft). Or it will be 128 if you started with WAV (Microsoft) and exported to MP3. It’s the MP3 to MP3 process that always loses quality.
Which is why we say, constantly, never do production in MP3.
There’s a producer that makes a music review radio show for broadcast by using downloaded MP3 clips. They do more or less OK all through the production, editing and broadcast process. It’s when the station tries to make a compressed podcast (another compression step) that the music quality goes straight into the toilet/loo.
He posted about the best way to avoid that.
Don’t do production in MP3.
If you have work that only involves cutting, pasting and moving stuff around (but no effects), then you’re far further ahead using a pure MP3 editor which doesn’t need to make a new MP3 and add sound damage.
