I would like to record short keyboard sessions played on a Nord Grand 2. I have no experiences with DAW applications. I have a connected my computer to the keyboard with a USB cable. That does not seem to be sufficient. How do I establish the connection?
The USB is probably just the MIDI information from the keyboard,
not the audio generated by the keyboard.
dmamfmgm » 19 Dec 2020, 21:44
The USB cable does not allow you to do the following:
- Record live audio from your Nord Grand. For that you would need to connect a separate Audio Interface to the 1/4" Audio Connections - either Left Out and Right Out,
Great info and advice. Thanks.
