Gaps in songs
I did search a little bit for this issue on here, but didn’t readily find it.
I have a USB turntable, and I am able to record onto my PC just fine, BUT,
some songs that have a slight gap in the middle of them - Audacity thinks that gap
represents a new song and records it as a ‘new’ song.
I know it is a setting somewhere, but I cannot find it.
Can someone point me in a direction?
Audacity 2.3.0 on Windows 10
Thank you in advance…
Audacity has no concept of “songs”, so it is not clear what you are talking about.
SO what do you so when you have songs that have a split-second gap in the middle of them?
Audacity does think it is two different songs, but if I want to put them on a CD
I can’t because they are not ‘altogether’ one song, and they should be?
I thought I ran across a setting somewhere that I could adjust for that gap, be it 2, 3 or 4 seconds, ie if
it is longer than, say 3 seconds, then it is a new song?
What do you mean?
