I am on Ubuntu 16.04 and I am using Audacity 2.3.1. Audacity often freezes and I have to shut down the program and restart it. The information I came across https://wiki.audacityteam.org/wiki/Linux_Issues suggests that it might have something to do with the pulse audio, so I tried to change it as indicated by starting up with a terminal. However, when I did this, I got the following messages even though Audacity did start:
env PULSE_LATENCY_MSEC=30 audacity
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2266:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm_route.c:867:(find_matching_chmap) Found no matching channel map
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for 4294967295, skipping unlock
Expression ‘stream->playback.pcm’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 4611
09:19:11: Debug: Unrecognized accel key ‘backspace’, accel string ignored.
09:19:11: Debug: Unrecognized accel key ‘numpad_enter’, accel string ignored.
** (audacity:5485): CRITICAL **: os_bar_hide: assertion ‘OS_IS_BAR (bar)’ failed
(audacity:5485): Gtk-CRITICAL **: IA__gtk_widget_hide: assertion ‘GTK_IS_WIDGET (widget)’ failed
** (audacity:5485): CRITICAL **: os_bar_set_parent: assertion ‘OS_IS_BAR (bar)’ failed
I’m not sure what this all means and perhaps it too has something to do with the freezes, so would welcome feedback. Also, I tried to modify audacity.desktop by including the Exec=env PULSE_LATENCY_MSEC=30 audacity %F, but audacity.desktop doesn’t seem to exist. There is simply audacity there in /usr/share/applications/, but all that does is open Audactiy. I do have hidden files visible.
Thank you.
