Forum question:
“This forum is for Audacity 2.x on Windows.
• Please state which version of Windows you are using, the exact three-section version of Audacity from Help > About Audacity and whether you obtained the .exe installer or the zip.”
I’m not sure about this part of this sentenance “whether you obtained the .exe installer or the zip”.
Properties in my audacity file says: “Application (.exe) -Audacity® 2.1.2 Setup-”.
So is this correct?
Yes the file “audacity-win-2.1.2.exe” is the Audacity installer. If you ran and completed the installer, you have installed Audacity.
