Hi,
I am having version audacity 2.1.0 and i forgot to save the project and i shutdown the program. After i realise my mistake i manage to find the temp files (which actually are all the files of the project cut to tiny pieces) is there any way to import all the details and then export the file to an MP3? Please bare in mind i am not expert with audacity.
If you still have the temp files then you should just be able to restart Audacity and it will show you an Automatic Crash Recovery dialogue from which you can recover the project.
If you cannot recover the project that way and if this project is an unedited recording, you can use the process on Recovering crashes manually. If the project is any other type of content, you can only import the AU files and try to piece them together by listening to them.
