I have this problem for some time and had hoped that it would be fixed in the new version. But it’s still here.
Drag & Drop a file from a folder on the desktop into Audacity.
Work with it, normalize it, export it.
Delete / Move the folder with the files
And now the problem: When I use now the “Macro” function, Audacity creates this folder from step 1 again. Without asking. When I delete this folder and use the Macro function again (which I do very often) the folder is there again!
It is simple: When I use drag and drop a file from a folder, Audacity is using this folder as default and when I delete it und use the Macro function Audacity creates this folder again if it not already exists. And this is the problem.
If it helps: maybe I can use a screen capture program and post a video from it?
So the folder “001” is being created when you click on the “files” button in the Macro dialog. Is that correct?
I can’t reproduce this on Linux. Perhaps it’s a Windows 10 thing.
Tested on Windows 10 and I can reproduce the problem.
What’s happening is that when the Audacity “File Import”, or “Macro > Files” dialog is opened, if the last used Import folder does not exist, Audacity is creating it. This should not happen (other applications don’t appear to do this on Windows).
