I am trying to record from the internet, but all I get is a flat line in both 2.1.0 & 2.1.1.
How do I fix?
Contents of Log:
1:16:34 PM: Audacity 2.1.0
1:16:34 PM: Trying to load FFmpeg libraries...
1:16:34 PM: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
1:16:34 PM: Looking up PATH environment variable...
1:16:34 PM: PATH = 'C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static'
1:16:34 PM: Checking that '' is in PATH...
1:16:34 PM: FFmpeg directory is in PATH.
1:16:34 PM: Checking for monolithic avformat from 'avformat-55.dll'.
1:16:34 PM: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
1:16:34 PM: Loading avutil from ''.
1:16:34 PM: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
1:16:34 PM: Loading avcodec from ''.
1:16:34 PM: Loading avformat from 'avformat-55.dll'.
1:16:34 PM: Error: Failed to load FFmpeg libraries.
1:16:34 PM: Error: Failed to find compatible FFmpeg libraries.
1:27:21 PM: Attempting to load LAME from system search paths
1:27:21 PM: Loading LAME from lame_enc.dll
1:27:21 PM: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
1:27:21 PM: load failed
1:27:21 PM: Attempting to load LAME from builtin path
1:27:21 PM: LAME registry key does not exist.
1:27:21 PM: Library path is:
1:27:21 PM: (Maybe) ask user for library
1:27:21 PM: Failed to locate LAME library
1:28:08 PM: Attempting to load LAME from system search paths
1:28:08 PM: Loading LAME from lame_enc.dll
1:28:08 PM: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
1:28:08 PM: load failed
1:28:08 PM: Attempting to load LAME from builtin path
1:28:08 PM: LAME registry key does not exist.
1:28:08 PM: Library path is:
1:28:08 PM: (Maybe) ask user for library
1:28:08 PM: Failed to locate LAME library
1:29:29 PM: Attempting to load LAME from system search paths
1:29:29 PM: Loading LAME from lame_enc.dll
1:29:29 PM: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
1:29:29 PM: load failed
1:29:29 PM: Attempting to load LAME from builtin path
1:29:29 PM: LAME registry key does not exist.
1:29:29 PM: Library path is:
1:29:29 PM: (Maybe) ask user for library
1:29:29 PM: Failed to locate LAME library
1:30:16 PM: Attempting to load LAME from system search paths
1:30:16 PM: Loading LAME from lame_enc.dll
1:30:16 PM: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
1:30:16 PM: load failed
1:30:16 PM: Attempting to load LAME from builtin path
1:30:16 PM: LAME registry key does not exist.
1:30:16 PM: Library path is:
1:30:16 PM: (Maybe) ask user for library
1:30:16 PM: Failed to locate LAME library
1:30:41 PM: Attempting to load LAME from system search paths
1:30:41 PM: Loading LAME from lame_enc.dll
1:30:41 PM: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
1:30:41 PM: load failed
1:30:41 PM: Attempting to load LAME from builtin path
1:30:41 PM: LAME registry key does not exist.
1:30:41 PM: Library path is:
1:30:41 PM: (Maybe) ask user for library
1:30:41 PM: Failed to locate LAME library
It’s not broken. Chances are good you just didn’t set up the computer right.
http://manual.audacityteam.org/o/man/tutorial_recording_audio_playing_on_the_computer.html
Self Recording is not a natural act or a manufacturer’s product. You’ll never find it on the list of features. You have to work for it.
