Alright, so this is an odd situation. I produce content for youtube, and recently tried to improve my audio by using an XLR mic with the current camera that I own. The camera, unfortunately only has a basic microphone jack. So, I acquired a converter cable that seemed to do the trick. I produced the video, it sounds good to me… but some viewers are unable to hear the audio recorded with the camera and aforementioned XLR mic. I’m assuming that this is because certain audio channels are not being represented, and therefore on some devices the audio drops out.
I have attached a test file I did with the mic. I ripped the audio from the video file I produced, and converted it to MP3 format in Audacity. However, even when trying to fix it in audacity and putting it back over the top of the video… the problem still comes up. Sadly, this is my best option until I can afford a camera with XLR audio in. But unfortunately, they are fairly expensive.
You can continue to use it that way, particularly if everything sounds OK except for the audio vanishing here and there.
While you have your stereo voice track before you use it anywhere else, “flip over” the right track. Note in the first five seconds or so, the upper blue wave and bottom one are mirror images of each other? That’s very wrong, but it can be fixed in post production.
Use the black arrow menu drop-down to the left of the blue waves.
Split Stereo Track.
Select the bottom one by clicking just above MUTE. Effect > Invert.
Top track pulldown > Make stereo track.
Done. The two tracks aren’t mirror image any more.
Neither the microphone nor the camera is broken. It’s just the wrong adapter for the job. The microphone naturally creates voice signals like that because that’s how it lets you use 50 and 100 foot long microphone cables—assuming you’re using a sound mixer or portable broadcast audio recorder.
You’re not.
I used to have a list of cable adapters you could buy to do this…
You won’t if you got the first step wrong.
Note the two blue waves are clearly opposite each other. One goes up and one goes down.
After you split stereo track, you should have something like this.
Now select the bottom wave by clicking just above MUTE. Then from the top toolbar, Effect > Invert.
Note the two waves are going the same way now?
Then just jam them back together into a repaired stereo show with Make Stereo Track.
Let me know.
I can unpack the magic, too. if you have a client, customer or posting that insists on a mono mix (one blue wave) rather than stereo (two blue waves), or is listening in mono, say on an iPhone speaker, your original track will drop dead (temporarily). Plug a full-on stereo headphone or earset into the bottom of the iPhone, and the show will come back to life.
It’s really crazy-making. “How come about a third of my customers can’t hear the show?”
Sorry about the late reply, but I was busy fixing everything in my video. Your advice worked, my video is now audible no matter where it is viewed… and you have my thanks.
Just to be crystal clear, you can continue to use your camera and microphone forever as long as you remember to do that little dance with the bottom audio track. The obsessive engineers are all jumping up and down about fixing it permanently, but I’m in favor of holding on tight if you find something that works.
Plus I can’t think of a good, graceful, easy way to fix it permanently.
