I have clips of speech where the beginning or the end of the talking is abruptly cut off. Its small like you can almost hear the entire word but the very last or first part of a word is chopped off and makes for a jarring transition.
I want to either fix or fake a fix so that it so that it sounds at least on casual listening to be smooth normal speech. Is there some technique to do this? I’m also open to nonaudacity solutions if necessary.
When I try to look things up everybody is just talking about fixing cut off peaks in high volume audio which is not what I want.
