First time set up - WASAPI recording - LOUD feedback
Audacity version 2.1.3 - Windows 10.
This is probably a dumb question, but I have no idea what I’m doing and would appreciate any input on how to fix this issue.
I can’t seem to search for the solution either, as I don’t know what I’m supposed to even search for.
When trying to record what I hear out of the speakers/headphones on my desktop, loud noise/feedback? occurs even when no noise is present.
Here’s a clip of what happens when I hit record.
https://streamable.com/bw1gf
You can get odd feedback like that if you have more than one service struggling to use the sound channels.
Did you set yourself up with these instructions?
https://manual.audacityteam.org/man/tutorial_recording_audio_playing_on_the_computer.html
Do you regularly use Skype, chat, or conferencing? On-line Games?
It’s actually pretty difficult to get screaming feedback like that. Many of the setups involve multiple passes through the computer and that can take up to a second.
That’s a condition, not a job. why do you want to do that? What’s the job? Record both sides of a Skype call for a document? Record a conference for a podcast?
Thank you. I read the instructions and the problem is fixed. Software Playthrough was enabled and causing that issue.
