Hello,
I’m currently running Audacity 2.0.5 on my Mid-2013 13-inch MacBook Air (base model) running OS X Mavericks Version 10.9.1.
I am editing sermons for my church to publish onto the local radio. I used to have an '09 Macbook Pro running OS X 10.8 and ran Audacity 2.0.5 on it with no exporting issues at all. Unfortunately, that computer crashed completely and I’ve since upgraded to my current Macbook Air in which I’ve been experiencing issues. With my new laptop, I’ve been editing sermons that have three separate tracks, that in total exact to a final time of 27:50. Whenever I export the sermon (whether MP3 or WAV), the first 5 seconds of the published file have a crackling sound. I am not certain as to why this keeps happening, but it is quite frustrating and any advice is more than greatly appreciated.
I’ve tried isolating the problem, but haven’t fully figured things out, so here are some other notes that I’ve observed
-Whenever I install Audacity, usually the first time I export with it, my final MP3 file comes out perfect. Any following times I export, I get the beginning 5 second crackle
-With that said… I’ve installed 3 different versions of Audacity (2.0.3, 2.0.4 and 2.0.5) with the same issue across the board
-I’ve exported each individual track separately into MP3 format and had absolutely no issues with them
-I’ve exported to WAV both before and after installing LAME to observe if the crackling occurred. It still did
In summary, I’ve come the following conclusion(s): The version of Audacity makes no difference upon the issue, the LAME plug-in is not the culprit of the issue, and lastly I can technically keep installing/deleting Audacity to export my final product, it is just very frustrating as I edit multiple times a week.
So I’m not certain if this is a general incompatibility issue between Audacity and OS X Mavericks 10.9.1, an issue with my files when arranged into multiple tracks (as each exported individually just fine), or something else.
I hope I offered a thorough enough explanation, and do greatly appreciate any advice. Also I have read a similar issue: https://forum.audacityteam.org/t/static-distortion-on-export/30123/1
but the solutions offered me no help unfortunately.
Thank you for your time,
Ryan
