Finding very short (10-20ms) silences in audio file
Hello,
I have been trying to use Analyse Silence and Sound to detect part of an audio where data is missing.
Analyze Silence and Sound do not allow me to specify a minimum duration bellow 100 ms.
Is there any way I can use Audacity to detect these issues in my audio files?
These holes in the audio are due to my system dropping samples. I would like to analyze/check my audio files to see if they have such gaps before publishing them.
These very short gaps are quite audible.
Thank you in advance
I tried using Vamp plugin Aubio Silence Test & Silence Region.
But they too don’t detect the very small duration sample drops.
