Find the makers
Hi, I would like to know where I can find the makers to select a portion of audio and copy it, delete it etc. On Bias Peak you can put a MARKER in a precise point and another afterwards and then select the track from marke to marker. How do you do it on Audacity? Thank you
:smiley: :smiley: :smiley: :smiley: :smiley:
Audacity has labels.
You can also use clips to mark audio.
– Bill
Can split the selected portion, or add a label track.
