Hey Guys!
I downloaded a plugin to find the peak. Works very Nice!
How i find the lowest volume?
Many Thanks!
Hey Guys!
Many Thanks!
Teh [u]ACX Check Plug-in[/u] will give you the “Noise Floor” from the quietest half-second. That might be total digital silence (minus infinity dB) at the beginning or end so it may not be useful, or the time-window might be wrong for you. (Of course you can ignore the pass/fail results.)
After installing, ACX Check will show-up under the Analyze menu. (You may have to enable it via the Effects menu.)
I will try ACX Check Plug-in
Many Thanks for the answers, guys!
