Why does my file suddenly become way to loud when recording?? Cannot fix with editing.
Make sure Windows “Enhhancemsnts” are disabled. That’s the most common cause of screwy results during recording.
You can adjust the volume setting of the input source in Windows settings. Currently my input (Windows 11) is set to 55. Settings, system, sound, select INput source and adjust slider. Possibly you can set channels and quality for the source, depending on what source it is.
Thank-you SO much for your suggestion! What I think is happening though is that something like a glitch or bug or something is CHANGING the file. The waveform suddenly becomes very large and EXTREMELY loud. Totally weird. Maybe a virus or malware. How to fix? I have done a scan with Norton to no avail…Thanks again…
