File menu;
In the “SAVE” process when I pull down the" File" menu the “Export Selection” category is grey (not available). How do I correct this so I can go forward with the process?
Press the yellow Stop button:
http://manual.audacityteam.org/o/man/faq_editing.html#grayed .
Gale;
Thanks for the info. There was one additional step however. I had to first open the “EDIT” menu and open “select” and click “all”.
Mel
If you’re exporting everything you can just use the Export command - rather than selecting all and then using Export Selection.
