'File formats' on preferences not visible..
Running Audacity 2.0.3 on Windows 7,
Currently stuck with 128kpbs bit rate , wanting to up it to 192. Using LAME mp3 codec installed in accordance with instructions. Can successfully export an mp3 in the correct format (mp3) but no access to format options…
Any help greatly appreciated.
**Moderator note:**Vulgarity removed, this is not a school playground! We strive to keep this a sane and family-friendly corner of cyberspace.
You need to click the “Options” button in the Export dialogue: http://manual.audacityteam.org/o/man/file_export_dialog.html
Problem solved. Nice one
