i am trying to install fmpeg but i was getting module not found but i fixed that with a reinstall of ffmpeg but now its saying that is not a valid windows application the full error is: 14:47:29: Error: Failed to load shared library ‘avformat-55.dll’ (error 193: %1 is not a valid Win32 application.)
log is attached below:
log.txt (6.92 KB)
If you’re running the 32-bit version of Audacity you need the 32-bit version of FFmpeg. They have to “match” so make sure you’ve downloaded the right one.
