FFmpeg library not found
Hello - I have audacity 2.0.5 running on a mac server - as root or admin - my instance sees the ffmpeg library - as a logged in user it doesn’t not.
Any suggestions on how the root / admin user can share the privs system wide with others? Am happy to post log entries from audacity if needed. Cheers.
Please do not tag a question onto the end of someone else’s solved topic - tempting as it might seem. I started a new topic for you.
Unfortunately you have not given any information on how you installed FFmpeg. Did you follow http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#macff ?
I would suggest right-click or control-click over the folder where you installed FFmpeg > Get Info and try configuring the folder permissions in the bottom of the window you come to.
