FFmeg problem
hello,
My Audacity log say’s alot of of error related stuff. I downloaded beat.ny into my plugin folder.
So i go-file /import/audio/beat.ny
then
Audacity says ,Audacity did not recognize that type of file.
i try importing as raw data ,and all i get is a a quick scatchy sound
Im not sure what i have done wrong ,but i cant seem to work it out.
Any help with this would be great thanks.
Files ending in “.ny” are not audio files, they are “plug-ins”
If you are trying to install a Nyquist plug-in, see the instructions here: http://audacityteam.org/download/plugins
Thanks
