I have a Fender super champ x2 amp with a usb out, so I can hook it to my computer
I have used this in the past to record to Audacity. for some reason Audacity doesnt recognize it now
the usb is good because I have fender fuse also on my computer and that works through the usb cable
Ive tried plugging in the amp then starting Audacity, and Ive tried plugging the mp in after Audacity is started
in the recording drop down box the super champ does not show up, ive been to preference and tried that too
I uninstalled audacity and re installed it . nothing has worked
anyone have any ideas?
thanks,
Try “Detecting USB and Firewire devices” here: http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#flatline.
Reinstalling Audacity does not reset it unless you enable the box “Reset Preferences” half way through the installer.
yep that was it,Thanks
Im not sure how it got changed, like I said I was able to record before
who knows, anyway thanks for the help
