Hi Im fairly new to Audacity…
I tryed to do some recording over the weekend. I plugged my mic into the Behriher Xenyx 1002FX mixer. I then plugged an RCA to stereo cable into the micer output and into the mic in input respectively. It recorded but i got heavy hiss and crackiling sound when i recorded it. Its not the mic becaise i plugged a guitar in and the same problem occured. The recording sounds great its just the crackling thats clouding it.
And help or suggestions would be greatly appreciated
The mixer output is line-level. You should connect to a line-input, not a mic input (color-coded blue on most soundcards).
If you have a laptop with only mic-in and headphone-out, the [u]Behringer UCA 202[/u] is an inexpensive interface with line-inputs. (Most regular “USB soundcards” are like laptops with no line-in.)
FYI - The mic input on a laptop or consumer soundcard is worthless for any kind of quality recording. It’s high-impedance unbalanced, which is the wrong interface for low-impedance balanced (XLR connector) performance or studio mics. (But. the impedance is not high-enough for guitar.) And, the built-in mic preamp is usually low-quality (noisy).
Feedback During Recording
Feedback is when the output (usually from the speakers) gets fed-back to an input (usually the mic). With a P.A. system, you’ll get a full-volume “squeal” noise. Sometimes there is a delay through a computer, so feedback can give you an echo. With guitar feedback you can get infinite sustain, since the strings are tuned.
It recorded but i got heavy hiss…
Hiss and hum are common types of noise (unwanted sounds).
…and crackiling sound when i recorded it.
Crackling could be a type of noise, but in your case I’m guessing it’s a type of distortion… Probably clipping, which is the most common type of distortion. Clipping is when you run-out of headroom (such as trying to get 110 Watts from a 100 Watt amp). Or in your case, you are probably overloading the analog-to-digital converter in your soundcard/soundchip. With clipping, the tops of your “waves” are squared-off.
