Feedback button should be easily available in Audacity 4 menu
If you’re serious about wanting to deliver what users need, you should provide a method in the app for providing feedback. Since I don’t see one, I’ll provide it here:
  • “End” key should take you to end of selected track; “Home” to beginning.
  • Missing the old “Track Size - Fit to Height” function. Should be an option to open files to full available height; adding files causes each to decrease height but still fill available vertical space.
  • What happened to “Export - Multiple”? I use this all the time!
  • Consider adding difference in RMS level in “Measure RMS” result:
(let ((rms (get '*selection* 'rms))) (if (arrayp rms) (format nil "~a: \t~a ~a~%~ ~a: \t~a ~a (~a ~a)~%~ ~a: \t~a ~a" (_ "Left") (linear-to-db (aref rms 0)) (_ "dB") (_ "Right") (linear-to-db (aref rms 1)) (_ "dB") (- (linear-to-db (aref rms 0)) (linear-to-db (aref rms 1))) (_ "dB") (_ "Stereo") (linear-to-db (stereo-rms rms)) (_ "dB")) (format nil "~a: \t~a ~a" (_ "Mono")(linear-to-db rms)(_ "dB"))))
(Not my work; it was provided by one of your admins when I originally asked about it.)
  • Include the “Amplify Left or Right Channel” effect; I can give it to you if you don’t have it.
  • When I create my first track label (CTRL+B), it does not switch focus to the label so I can type it in.
  • When it says “Restart to apply new settings” and I click on “Ok”, it should restart.
I’ll stick with v.3 for now, but will check back after some time to see how v.4 is progressing. Thanks.
Also, I can’t figure out how to migrate my old VST3 plugins. I put them in my user’s “Audacity4\Plugins” folder, but they don’t show up even after an app restart and plugins rescan.
