I can confirm segmentation faults occurring on:
- Fedora 19
- both audacity-2.0.3-1.x86_64 and audacity-2.0.4-1.x86_64
- audacity-freeworld-2.0.4-1.x86_64
Reproducer:
Start audacity
Generate|Sine| defaults 30 seconds long.
Effect|Equalizer
What happens:
audacity disappears.
when run from command prompt:
Program received signal SIGSEGV, Segmentation fault.
0x0000000000655e27 in EqualizationDialog::MakeEqualizationDialog() ()
Under gdb:
(gdb) thread apply all bt
Thread 10 (Thread 0x7fffe9ed3700 (LWP 13251)):
#0 0x0000003f73a0e80d in nanosleep () at ../sysdeps/unix/syscall-template.S:81
#1 0x0000003f7beedc1c in wxMicroSleep(unsigned long) ()
from /lib64/libwx_baseu-2.8.so.0
#2 0x000000000052c41c in AudioThread::Entry() ()
#3 0x0000003f7bee9573 in wxThreadInternal::PthreadStart(wxThread*) ()
#4 0x0000003f73a07c53 in start_thread (arg=0x7fffe9ed3700)
at pthread_create.c:308
#5 0x0000003f732f5d3d in clone ()
at ../sysdeps/unix/sysv/linux/x86_64/clone.S:113
Thread 2 (Thread 0x7fffec635700 (LWP 13242)):
#0 0x0000003f732eb76d in poll () at ../sysdeps/unix/syscall-template.S:81
#1 0x0000003f75a480f4 in g_main_context_poll (priority=2147483647, n_fds=5,
fds=0x7fffe4009e30, timeout=-1, context=0xe27ac0) at gmain.c:3995
#2 g_main_context_iterate (context=0xe27ac0, block=block@entry=1,
dispatch=dispatch@entry=1, self=<optimized out>) at gmain.c:3696
#3 0x0000003f75a4855a in g_main_loop_run (loop=0xe27a50) at gmain.c:3895
#4 0x0000003f786c6d66 in gdbus_shared_thread_func (user_data=0xe27a90)
at gdbusprivate.c:278
#5 0x0000003f75a6c185 in g_thread_proxy (data=0xe9d370) at gthread.c:798
#6 0x0000003f73a07c53 in start_thread (arg=0x7fffec635700)
#7 0x0000003f732f5d3d in clone ()
Thread 1 (Thread 0x7ffff7f9aac0 (LWP 13235)):
#0 0x0000000000655e27 in EqualizationDialog::MakeEqualizationDialog() ()
#1 0x00000000006601fe in EqualizationDialog::EqualizationDialog(EffectEqualization*, double, double, float*, float*, long, wxString, bool, wxWindow*, int, wxString const&, wxPoint const&, wxSize const&, long) ()
#2 0x000000000066049c in EffectEqualization::PromptUser() ()
#3 0x000000000062a7e9 in Effect::DoEffect(wxWindow*, int, double, TrackList*, TrackFactory*, double*, double*, wxString) ()
#4 0x0000000000586103 in AudacityProject::OnEffect(int, Effect*, wxString, bool) ()
#5 0x00000000005867cb in AudacityProject::OnEffect(int, int) ()
#6 0x0000000000619f48 in CommandManager::HandleCommandEntry(CommandListEntry*, unsigned int, unsigned int) ()
#7 0x0000000000596d17 in AudacityProject::OnMenu(wxCommandEvent&) ()
#8 0x0000003f7beea676 in wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) () from /lib64/libwx_baseu-2.8.so.0
#9 0x0000003f7beea71b in wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) () from /lib64/libwx_baseu-2.8.so.0
#10 0x0000003f7beeaa87 in wxEvtHandler::ProcessEvent(wxEvent&) ()
#11 0x0000003eefa5b7f5 in gtk_menu_clicked_callback ()
from /lib64/libwx_gtk2u_core-2.8.so.0
#12 0x0000003f7720fa28 in g_closure_invoke (closure=0x1229c70,
return_value=return_value@entry=0x0, n_param_values=1,
param_values=param_values@entry=0x7fffffffd400,
invocation_hint=invocation_hint@entry=0x7fffffffd3a0) at gclosure.c:777
#13 0x0000003f77220a3d in signal_emit_unlocked_R (node=node@entry=0xe31000,
detail=detail@entry=0, instance=instance@entry=0x12280c0,
emission_return=emission_return@entry=0x0,
instance_and_params=instance_and_params@entry=0x7fffffffd400)
at gsignal.c:3584
#14 0x0000003f77228829 in g_signal_emit_valist (instance=<optimized out>,
signal_id=<optimized out>, detail=<optimized out>,
var_args=var_args@entry=0x7fffffffd588) at gsignal.c:3328
#15 0x0000003f77228a72 in g_signal_emit (instance=instance@entry=0x12280c0,
signal_id=<optimized out>, detail=detail@entry=0) at gsignal.c:3384
#16 0x0000003eede6913c in IA__gtk_widget_activate (
widget=widget@entry=0x12280c0) at gtkwidget.c:5048
#17 0x0000003eedd572ed in IA__gtk_menu_shell_activate_item (
menu_shell=0x120d250, menu_item=0x12280c0,
force_deactivate=<optimized out>) at gtkmenushell.c:1303
#18 0x0000003eedd5769c in gtk_menu_shell_button_release (widget=0x120d250,
event=<optimized out>) at gtkmenushell.c:730
#19 0x0000003eedd426ec in _gtk_marshal_BOOLEAN__BOXED (closure=0xe21fb0,
return_value=0x7fffffffd840, n_param_values=<optimized out>,
param_values=0x7fffffffd8f0, invocation_hint=<optimized out>,
marshal_data=<optimized out>) at gtkmarshalers.c:86
#20 0x0000003f7720fa28 in g_closure_invoke (closure=closure@entry=0xe21fb0,
return_value=return_value@entry=0x7fffffffd840, n_param_values=2,
param_values=param_values@entry=0x7fffffffd8f0,
invocation_hint=invocation_hint@entry=0x7fffffffd890) at gclosure.c:777
#21 0x0000003f772207fb in signal_emit_unlocked_R (node=node@entry=0xe22000,
detail=detail@entry=0, instance=instance@entry=0x120d250,
emission_return=emission_return@entry=0x7fffffffd9c0,
instance_and_params=instance_and_params@entry=0x7fffffffd8f0)
at gsignal.c:3622
#22 0x0000003f77228462 in g_signal_emit_valist (instance=<optimized out>,
var_args=var_args@entry=0x7fffffffda88) at gsignal.c:3338
#23 0x0000003f77228a72 in g_signal_emit (instance=instance@entry=0x120d250,
#24 0x0000003eede6a474 in gtk_widget_event_internal (
widget=widget@entry=0x120d250, event=event@entry=0x1396ee0)
at gtkwidget.c:5017
#25 0x0000003eede6a749 in IA__gtk_widget_event (widget=widget@entry=0x120d250,
event=event@entry=0x1396ee0) at gtkwidget.c:4814
#26 0x0000003eedd40934 in IA__gtk_propagate_event (widget=0x120d250,
event=0x1396ee0) at gtkmain.c:2490
#27 0x0000003eedd40cfb in IA__gtk_main_do_event (event=0x1396ee0)
at gtkmain.c:1685
#28 0x0000003eee45e2dc in gdk_event_dispatch (source=source@entry=0xdef340,
callback=<optimized out>, user_data=<optimized out>)
at gdkevents-x11.c:2403
#29 0x0000003f75a47e06 in g_main_dispatch (context=0xdef430) at gmain.c:3054
#30 g_main_context_dispatch (context=context@entry=0xdef430) at gmain.c:3630
#31 0x0000003f75a48158 in g_main_context_iterate (context=0xdef430,
block=block@entry=1, dispatch=dispatch@entry=1, self=<optimized out>)
at gmain.c:3701
#32 0x0000003f75a4855a in g_main_loop_run (loop=0x12ec7e0) at gmain.c:3895
#33 0x0000003eedd3fdb7 in IA__gtk_main () at gtkmain.c:1257
#34 0x0000003eef9f624a in wxEventLoop::Run() ()
#35 0x0000003eefa70e4c in wxAppBase::MainLoop() ()
#36 0x0000003f7be9722d in wxEntry(int&, wchar_t**) ()
#37 0x0000000000500042 in main ()
At this point, audacity is not playing/recording audio, so seems UI / processing related.
