Feature suggestion: Move Selection
I love using the left and right arrows in combination with in order to select parts of the track. Combining the functionality with is great in order to correct/re-adjust the boundaries.
In addition, I would love to have the new functionality of + left and right arrows in order to move the selection.
(I often cut parts of pre-defined length out of the tracks and I do this at different track positions. So a simple keyboard shortcut would speed-up my workflow.)
OK. There is a quick non-keyboard method. Label the selection then drag on the white circle on either label edge to move the label.
Transferred to Wiki>Pending Feature Requests - and moved on the Forum to “Audio Processing” as this is a useful tip for others.
