When recording using the Sound Activated Recording feature the resulting recording often leaves unnatural short gaps between words and/or sentences. It would be great to have a feature that can set a minimum gap length A to trigger the pausing of the recording and a minimum gap length B that should be kept if the gap is longer then a set value C. IE. If gap shorter than A=0.5 sec don’t stop even if level is lower than threshold. If gap longer than A=0,5 sec and shorter than C=1 sec keep original gap length and if gap longer than C limit gap to B=0,75 seconds.
