Can I ask for 2.4.0 faster workflow with the UI to minimize the number of clicks and more productive.
It is obviously that the intention of the Audacity development team, to make the GUI as clear, efficient, ergonomic and intuitive as possible. If you have suggestions to make Audacity more efficient, clearer, more ergonomic, more intuitive, please describe clearly and distinctly what your suggestions are.
One way you can slick up you workflow is to use the default keyboard shortcuts and define your own custom shortcuts
https://manual.audacityteam.org/man/keyboard_preferences.html
https://manual.audacityteam.org/man/keyboard_shortcut_reference.html
If you have repeated steps in you workflow you can create Macros
https://manual.audacityteam.org/man/macros.html
You can create Macros with your favoured settings pre-set for effects
You can even create shortcuts for your Macros
