IMHO It doesn’t really need a fast forward. You can place your cursor exacly wher you like and then play from there - zooming out helps with this - and you want want to zoom to fit the project to the screen. Much more flexible than a tape palyer’s FF/FR.
In 1.3 there is a new toolbar , the Selection Toolbar. This lets you enter times to move the cursor to.
You can also use:
cursor right and left keys to scroll horizontally.
comma and full stop (lower case “<” and “>” keys) to make small jumps left and right
Shift+< and Shift+> to make large jumps left and right
Home key = go to the beginning
End key = go to the end
Look in “Preferences > Keyboard” for a full list of keyboard short cuts.
