Hey there!
Is there a chance to remove or reduce a very bad power line hum (attached sample)?
We’d unwisely used Hi-Gain option on the iRig Mic cast to record an interview.
The location had several industrial refrigerators and smoking equipment, a place where make sausages.
The interfering frequency is too high to be mains hum.
Notch filters [in Audacity’s Nyquist Prompt ] help a bit …
(setf s (notch2 s 1073 20))
(setf s (notch2 s 3384 50))
(setf s (notch2 s 5533 50))
(setf s (notch2 s 6606 20))
(setf s (notch2 s 7680 50))
(setf s (notch2 s 12141 20))
Hey there! Thanks for the fast response and suggestions, really appreciate it.
We’ve finally managed to download the original wav file (please see the attached sample) from iRig (IK Multimedia site).
So if I understand this correctly, there is no way to get a “cleaner” audio, without that interfering frequency?
The constant tones (which are horizontal lines on the spectrogram) can be removed with notch filters (see my previous post)
However the constant tones have distorted the voices with a ring-modulator effect, which, IMO, isn’t removable.
