Exporting wav problem after a crash
Hi,
I’ve been recording three acoustic guitar tracks with Audacity, but in the middle of the process, the program had crashed. I recover the file as usually when it happens. The problem now is… when I export to wav the final work, the file doesn’t sound at all out of Audacity. In the program I can hear it well, but the wav doesn’t sound on Windows Media Player or others. With the rest of my workings I have not any problem, I can export and it sounds good out of it, but with this file doesn’t work. I don’t know if the crash is responsible for that or what happens, but I need to solve this problem urgently…
Thanks.
Crashes should not be happening “usually”.
Please look at Help > About Audacity. If it does not say 2.0.3, upgrade here: http://audacityteam.org/download/windows .
Try setting the Windows default playback device to use the playback device you are trying to listen to. For example, if you are using headphones, set the playback device to headphones. See “Sound” or similar in the Windows Control Panel.
