exporting to wav
Hi, I’m new to Audacity and I recorded a tune and saved to “export to wav” …so where do I find the wav?
Some versions of Audacity mistakenly export your work to the system folders as default. They’re a little rough to get to and doing that is a bad idea.
File > Export: WAV and see where the dialog is trying to put your work.
I usually go through the Desktop for everything and then create custom folders after the job.
