Exporting/Save Issues
Recorded two episodes for a podcast today. The first one saved and exported just fine. The second episode, however, I cannot get to save or export. Every time I go to save or export the file the software freezes up until it gives me error messages saying it can’t write to where I’m trying to save. Again, I had previously saved and exported a file just an hour prior to attempting the save and export of file two.
I’m running the latest edition of the software. Here is the error log. Can anyone tell me what, if anything, I can do to fix the issue? Thanks and very much appreciated in advance.
01:51:16: Audacity 2.2.2
01:51:16: Trying to load FFmpeg libraries...
01:51:16: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
01:51:16: Looking up PATH environment variable...
01:51:16: PATH = 'C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\WINDOWS\System32\OpenSSH\;;C:\Users\MediaLaptop\AppData\Local\Microsoft\WindowsApps'
01:51:16: Checking that '' is in PATH...
01:51:16: FFmpeg directory is in PATH.
01:51:16: Checking for monolithic avformat from 'avformat-55.dll'.
01:51:16: Error: Failed to load shared library 'avformat-55.dll' (error 126: the specified module could not be found.)
01:51:16: Loading avutil from ''.
01:51:16: Error: Failed to load shared library '.dll' (error 126: the specified module could not be found.)
01:51:16: Loading avcodec from ''.
01:51:16: Loading avformat from 'avformat-55.dll'.
01:51:16: Error: Failed to load FFmpeg libraries.
01:51:16: Error: Failed to find compatible FFmpeg libraries.
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808269.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e08086c0.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808749.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e08088a6.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e080891c.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808941.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e08089ee.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808a2e.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808aa0.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808e8b.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808ebd.au'
01:51:21: Warning: Orphan block file: 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d08\e0808f16.au'
01:51:21: Warning:    Project check ignored orphan block file(s). They will be deleted when project is saved.
01:51:21: Warning: Project check found file inconsistencies inspecting the loaded project data.
01:56:36: Attempting to load LAME from system search paths
01:56:36: Loading LAME from lame_enc.dll
01:56:36: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
01:56:36: load failed
01:56:36: Attempting to load LAME from builtin path
01:56:36: LAME registry key exists.
01:56:36: Library path is: C:\Program Files (x86)\Lame For Audacity
01:56:36: Loading LAME from C:\Program Files (x86)\Lame For Audacity\lame_enc.dll
01:56:36: Actual LAME path C:\Program Files (x86)\Lame For Audacity\lame_enc.dll
01:56:36: LAME library successfully loaded
01:56:37: Attempting to load LAME from system search paths
01:56:37: Loading LAME from lame_enc.dll
01:56:37: Error: Failed to load shared library 'lame_enc.dll' (error 126: the specified module could not be found.)
01:56:37: load failed
01:56:37: Attempting to load LAME from builtin path
01:56:37: LAME registry key exists.
01:56:37: Library path is: C:\Program Files (x86)\Lame For Audacity
01:56:37: Loading LAME from C:\Program Files (x86)\Lame For Audacity\lame_enc.dll
01:56:37: Actual LAME path C:\Program Files (x86)\Lame For Audacity\lame_enc.dll
01:56:37: LAME library successfully loaded
02:17:46: Error: Failed to copy the file 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d00\e0800b0b.au' to 'C:\Users\MediaLaptop\Desktop\102_data\e08\d00\e0800b0b.au' (error 23: data error (cyclic redundancy check).)
02:18:00: Error: Directory 'C:\Users\MediaLaptop\Desktop\102_data' couldn't be deleted (error 145: the directory is not empty.)
02:25:52: Error: Failed to copy the file 'C:\Users\MediaLaptop\AppData\Local\Audacity\SessionData\project15127\e08\d00\e0800b0b.au' to 'E:\102_data\e08\d00\e0800b0b.au' (error 23: data error (cyclic redundancy check).)
02:25:59: Error: Directory 'E:\102_data' couldn't be deleted (error 145: the directory is not empty.)
Running Windows 10
Latest edition of Audacity
Downloaded today using exe
What is the version number? (Look in “Help menu > About Audacity”)
What is the “E:” drive?
How much space is there on the “C:” drive?
