Time (s) | Pitch (Hz)
1 400
2 600
3 440
4 880
5 700
6 700
If there is, how would I do this? If not, is there any open source program that you know of that would work?
Do you actually have one-second-long blocks of sine tones? Otherwise, what about the complexities of key signature or pitch detection in a piece of complex music, before we get to exporting it as data?
If you use Analyze > Plot Spectrum…, and choose an “Autocorrelation” choice or the “Cepstrum” choice you can export a text file containing columns for “Lag”, “Frequency” and “Level”. “Enhanced Autocorrelation” is probably the best choice for Pitch determination. That is all I know of, unless there are Nyquist Prompt methods.
It depends what your actual goal is. I don’t use it, but Sonic Visualiser has some export features.
