Exporting multiple channels by label
Hi all,
I’ve got a multi-track recording of a concert. I’ve added labels where each song starts and stops and I’d like to export each track for each song as a separate M4A file. It appears from the export dialog that I can only split by label or by track, but not both. I have two questions:
  1. Is this possible in some other way that I’m not aware of, or is there some workflow I should use to manually go through and split this out (I did find a vaguely similar question about this, but it was about saving multiple audacity projects so I can imagine the answers would be different? Maybe not though, if so, sorry for the noise)
  2. Is there a feature request or other place where this has been discussed that I could vote for (I didn’t find one, but you may know more than me)
It seems odd to me that “Multiple File” is a separate option from “Current Selection” in the drop down box, these don’t seem like an either/or to me, so hopefully someone else will have a better way to handle this.
Thanks for your help.
