Exporting for Jlipsync
Hi, might seem like an ignorant question but i’v been trying to record an 8 bit mono file that will open in jlipsync for awhile and cant seem to find where to convert the recording or exporting to 8 bit…Please help any assisstance would be appreciated. I’m using Windows Vista…
This part of the forum is for issues relating to the forum itself. There are sections for Audacity 1.2.x and another for 1.3.x on Windows. You should be using Audacity 1.3.11 on Vista.
Assuming that you are using Audacity 1.3.11, in the Export dialogue, select “Other Uncompressed Files” as the file type, then in the “Options” select “WAV Microsoft - Unsigned 8 bit PCM”
