Exporting files
After digitizing an LP I wanted to export the newly created file (at this time I don’t want to deal with projects), and during the procedure I would like to have control of the subfolder where the file will be saved.
I definitely don’t like the default subfolder (If I remember well it is the Documents subfolder, a definite no-no to save any audio file), so in each case I had to navigate to the subfolder I wanted the AIFF file to be saved. A bit of a hassle to do it every time.
I tried to find a setting in the Preferences, but I couldn’t.
I am running MAC OSX 10.9.5 on a one year old iMac.
Any suggestions?
If you’re digitizing LPs, most people want to break up the show into songs and then export the songs.
http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
Where did you tell the system to save the file? I changed it to my desktop and it just does it there every time. I thought it defaulted to the /Applications folder (it used to) and that’s a serious problem. I don’t remember how I did it. I think I just Exported a sound file there once and it stuck.
Are you an administrator on your machine?
