Using Windows 10, Audacity 2.1.2
I know next to nothing about audio files or audio editing, but I have been asked to use Audacity to do some very simple editing of some recordings of bird songs. They were recorded in the 24 bit WAV format, and I am supposed to upload the files, after editing, still in 24 bit WAV
I was told that after editing, I would find that “24 bit WAV” would not be one of the options for exporting a finished file, but that I could choose “other uncompressed files” and in Uncompressed Export Setup select Header: WAV and Encoding: Signed 24 bit PCM.
However, when I follow these directions, my file ends up with an AIFF extension, and will not work.
Can anyone advise me how to do this, so that I end up with a 24 bit WAV file?
Thanks!
