Try temporarily disabling “dither” in “Preferences > Quality” (set “dither” to “None”).
Normally dither should be set to “shaped” for high quality conversion, so remember to change it back when you’re done. Full information about dither can be found here: https://manual.audacityteam.org/man/dither.html
This workaround should not be necessary in the next version of Audacity.
the exported track was a tiny bit smaller in size (as it should be) after editing off the tiny bit of silence at the beginning and end
i dont remember ever having to do this for any other track before. the only difference i know about is i just started listening to ambient music so this might be the first very quiet slow light type track i exported. or the first time i noticed the size when exporting a quieter type of track
which version should i keep? the smaller one with no dither or the bigger one with the dither?
You don’t need dither unless you are reducing the bit depth.
And at 16-bits or higher it’s not THAT important one way or the other because under normal listening conditions you can’t hear dither or the lack of dither.
A 8-bits you can hear the dither noise, and without it you can hear quantization noise. I never work in 8-bits but there was a thread here a couple of weeks ago where the person preferred it without dither.
Maybe…? Dither is noise and the randomness of noise makes it hard to compress. The louder music may already be more dense/complex and adding a little noise may not make it much harder to compress. And/or the louder music may already have noise. Almost anything recorded with a microphone has some acoustic and/or electrical background noise.
