Exported file does not play
I used Audacity faithfully and now got a problem. I have Windows 10. I ripped using WMP, and I import the files in audacity. I apply bass if I need to or to save to save space. When exported the file exports, but has no length and wont play. It used to work previously. Using the latest version of Audaity
They play OK in Audacity before exporting? What format are you exporting to?
What?
How long is it supposed to be (playing time)? What’s the file size?
Please always give us the Audacity three-part version number - some sites you can download Audacity from do not have the latest version. If you download from http://www.audacityteam.org/download/ you will always find the latest version there.
What format are you exporting to and where are you playing that exported file? If you are exporting to MP3, try choosing “Constant” Bit Rate when you export.
Is the problem with burning back to CD? If so, drag the file into the Media Player Library or into a playlist first, then from there into a burn list.
