Export
I have a lot of music on my computer and I would like to play them thru wave how do I get them to play and run thru export if possible. I use to be able to do this time but no good fortune. When I click on export nothing happens If I do ctr-shift-s it save them to auda city which I cannot fine most of the time.
Thanks
Assuming you have the current version of Audacity - File → Export → Export As WAV.
What format do you have now?
When you open the file do you see the blue waveform, and can you play it in Audacity?
That will create an Audacity project which can only be opened in Audacity.
