Export Problem
Hello,
I have a problem when I export the tracks: when I record a sound (principal track) and I want to add others with like panoramics, everything is OK, it sounds good so I export it. But when I listend to the result, it’s very different and there’s no panoramics. I’m not an expert so maybe it’s a simple problem but…
Thanks
I don’t know what you mean by the word “panoramics”.
If you mean stereo effects, is the exported show in stereo? Does it have two blue waves and are they different? Did you use File > Export Audio or File > Export Selected Audio?
