Export problem in File 6 channels
Hello :smiley: ,
I use Audacity hugely 2.02 (.exe installer) with windows seven SP1. Today I wanted to export a 6 channel AC3 file and Audacity said “In the Exported file, your tracks will be mixed into a single channel.” I uninstalled and installed again but it did not fix the problem.
What’s going on there?
Best Regards
Translated with Google
Go to Edit → Preferences → Import/Export and choose Use Custom Mix.
Thank you very much it works. It is not by default? (I also had to change in 448 kbps and 48000 Hz) I do not remember. Long ago I installed Audacity. I had a blue screen, it is probably this that has deregulated Audacity :wink:
Best Regards.
Translated by Google
