export multiple
Windows 10 home vs21H2 os build19044.1526 Audacity 3.1.3
Trying to export a recording that’s ready to export. At export multiple, going thru the steps in tutorial
When I come to the choose option, where can I sent my file so it will drag and drop into Itunes?
I put it into windows file explorer will drag but not drop. Am new to Audacy and not very good on puters. Any help be appreciated.
:question:
Almost anywhere… Maybe your Music folder? :wink: Maybe wherever your other iTunes files are (if you already have some).
But, I’d recommend making a separate-temporary folder (It can be in your main music folder) until you’re sure they are good. I make a folder for each album so whatever I’m saving would already be in its own separate folder.
iTunes doesn’t care how you organize your files & folders. You can leave it anywhere and add it to your iTunes (or other player) library. As long as the files are “tagged” with artist/album/song information your player software will be happy.
