Export multiple Numbering after Label/Track name after the filename prefix
Hello everyone
I’m new to the forum and the Audacity software.
I’m contacting you about the Multiple Export files at once using Label/Track name.
On Audacity 2.3.3, there are 3 ways to rename the file according to the marker :
  • Using Label/Track name
  • Numbering before Label/Track name
  • Numbering after File Name prefix
Would it be possible to rename the file with :
  • Numbering after Label/Track name after the filename prefix?
Thank you in advance for your help!
It would be “possible” to add hundreds of different naming options, but the developers decided not to do that.
