Export Multiple Labled tracks not working [SOLVED]
I labeled all track from a live album & every time I go to export multiple it records all under the first labeled tracks name all in one file. I do not see anywhere if we are to select tracks for exporting or not or if we select the labeled tracks. Please help, I follow the instruction but I do not get the same results
Please look at the pink panel at the top of the page and answer the questions. If you don’t have Audacity 2.0.6 from http://audacityteam.org/download/windows then the Export Multiple documentation in the Manual won’t make sense.
Also see Splitting a recording into separate tracks.
Yes I have the correct version & also figured out what I was doing wrong, go it working now. Thanks! amazing software!
