EXPORT MULTIPLE ISSUES
Hey Guys, I never experienced this problem in all the years using AUDACITY (usually smooth). My problem is as follows:
  • Every time I try to export multiple in order to get the separate tracks, each track exported is too large and too long.
  • I have tried to export in every setting possible and still have the same problem.
  • I have tried both AUDACITY 2.1.2 and the older 2.1.1 both yielding the same result.
Any help would deb greatly appreciated.
It doesn’t give you the sound between the labels? Did you put a label at the beginning?
Does your track start at the beginning of the timeline?
Did you put punctuation marks or non-ISO dates in the labels? Today is 2016-09-22, not 9/22/16.
Have you checked disk space?
I think it is this issue as per http://wiki.audacityteam.org/wiki/Release_Notes_2.1.2#Label_Tracks:
Export multiple by labels may add unwanted silence to exported files if multiple tracks are present that don’t all start at time zero. You can workaround this by using Edit > Select > All then Tracks > Mix and Render to render the audio to one track, or by generating a short amount of silence at the start of each track that is offset from zero.
This will be fixed in the next 2.1.3 version of Audacity when released later this year.
