Export multiple - clear the details of all exported WAV files in one click
Hi,
I want to import a WAV file and label it, then export it as multiple to save each labelled part as an individual file, but I don’t want to clear each exported part alone (by clicking “clear” then “ok” multiple times) because there is no available option to clear the details of all exported files at once.
Thank you.
I presume you mean the OKing to accept the metadata for each file.
If that’s the case then just turn that optoion off.
It’s an option in Edit > Preferences Import/Export: https://manual.audacityteam.org/man/import_export_preferences.html
