Hi,
I have several custom chains I’ve created that I want to copy to another computer / installation
Is it this possible? At the moment, I’m just redoing them all manually
Thanks
Hi,
Thanks
If you are using the same version of Audacity on both machines, and have all of the necessary effects installed, then you should be able to just copy over the chain .txt files from the “Chains” folder.
See the bottom of this page: http://manual.audacityteam.org/o/man/edit_chains.html
