EXPORT BUG 3.1.3 - Monterey
When I export a single file, usually I can just begin typing and it will automatically start typing in the “save as” field. Now I have to physically click the “save as” field in order to type. I have tried using the tab key and that also does not highlight the “save as” field. It would be great if you could restore this feature of simply typing to activate the “save as” field in export. THANK YOU! :smiley:
